Background
The intention was always to network the individual detectors together to allow for real-time (or near real-time) collection of event data. Several technologies and solutions were investigated. This log entry describes these investigations.
Configurations considered ranged from using a networking module attached to a microprocessor to a higher powered System on a Chip (SoC).
The main detector boards send raw output as voltage pulses (width?) on three wires which can be read directly by a connected controller. The initial design had these pulses being the output from the coincident circuits and so represented the red, green, blue (and white) channels. These pulses with a suitable electronic drivers could be used to power solenoids for operating mechanical noisemakers, corresponding to the detected events.
The networking technologies discussed:
- LoRaWAN networking - Adelaide has a growing IoT network encouraging the growth of Open Data. Still growing. https://www.thethingsnetwork.org/community/adelaide/
- Zigbee - This might have been useful. Ultra low power modes are available, but modules are more expensive and need to be placed
- Bluetooth - Range might have been an issue across the area required.
- WiFi - Well established and understood technology, cheap and available.
Wifi modules considered:
- ESP8266 Module - 3.3V module which, in default configuration, uses AT text commands over a serial connection.
Microprocessors (and microprocessor boards) considered:
- Arduino UNO R3, by keyestudio. This uses the ATMEL Mega16u2 for handling the USB-to-Serial interface. It is possible to reprogram this chip so that the Arduino board can be made to look like another device on the USB interface, like a keyboard or mouse. We probably won’t use this for this project, but together with the ESP8266 Module this might provide a very easy mechanism to log data from the network.
"System on a Chip"s that were considered:
- Raspberry Pi 3 with Wifi - Very useful as a development environment.
- Raspberry Pi Zero W (with Wireless) - Cheaper than the Pi3 and still very capable of doing what we need.
- Adafruit Feather HUZZAH with ESP8266 WiFi - Looks very useful and cheap. It's programmable via Arduino IDE and comes with battery management for a final (polished) detector system.
The price of units was also a consideration as it is hoped that over 100 detectors could be build for a future system spread over the area. Other constraints considered:
- Constrained build time - the solution is build from well known technology to minimise any required development work (+Wifi, -Other networking options)
- Deployment should be as simple as possible.
- What is on hand and/or easy to acquire?
The initial solution will definitely be a hack. A second iteration would be expected to see system changes.
Proposal
For each detector:
- Raspberry Pi Zero with Raspbian Operating System.
- Connected via GPIO pins to detector for events.
- Connected to Wifi access point, pre-configured with network Id (say ‘cosmic-ray’) and password.
- Sends event data to central server.
For the Access point router and network server:
- Powered by 12V battery
- Allocates IP addresses via DHCP (may be fixed to assist with identifying deployed units)
- Deployed with longer range, higher gain omni-directional antenna (flat antenna pattern).
For the network server
- During development, the server could be a laptop.
- For deployment, a laptop could be used, together with a tethered phone for transmitting data to other consumers on the internet.
Networking and Data Protocol
- Detector client software triggers on a detection event and sends a UDP packet to the server, which records the data.
Other useful ideas and thoughts:
- Add a back channel to allow the controller to control/set the outputs on the detector. Useful for testing and deployment. The system could then also be used as a distributed display, suitable for placing in building windows etc.
- Raspberry Pis can be booted from a single image and then individually configured via the network and MAC address.
- Remote administration can be done via SSH and ansible (for example) for managing the detector array.
