Completion of third prototype
A project log for Mica Sunglasses
Muscovite Optics
david-troetschelDavid Troetschel 07/18/2019 at 01:130 Comments
The end result:
Linear build process:
Sanded frames
Cleared arm pivots and test painted, then painted.
Went with dark green.
Then the lens assembly:
Testing:
Following two images are with same lighting, but variation in polarization.
Finally putting that HdP to use haha.
I'm still working on the arm design, thankfully it's easy to work with.
Ended up lengthening the arms.
I ended up tweaking the arms a lot, ended up drawing them into an arch.
Finished.
