Frame Assembly Part 1
A project log for CNC in a box
A simple CNC, storable and flexible enough to handle few use cases
vincentmakesvincentmakes 06/17/2019 at 07:180 Comments
I started to put together the frame. The between hole distance of the bearings KP08 doesn't match the rails of the aluminium profile. However, those bearing have also a ball joint in order to compensate for any misalignement so I took advantage of it and 'tilted' the bearing till it was matching the rails. The result looks a bit strange and crooked but it looks like it will work
