Secret to overcome "crazy howling" of 7-seg VFD.
A project log for Vacuum tube game in 21st century
Playing vacuum tube is not so difficult as expected. Let's play great heritage of human being by modern technology!
kodera2tkodera2t 07/16/2019 at 13:062 Comments
I know 7-seg VFD is NOT for audio amplifier but digit display, and I am rather "crazy", but eventually I overcome "crazy howling" issue. Without any trick, triode operation 7-seg VFD will cry and howl up to maximum its output. Unless your house is like " Little house on the Prairie", your neighbour will get angry for continuous noisy howling.
What's the trick? It is indeed conventional way to stabilize howling of direct-heated tube, putting magnet on the tube.
The picture above shows the actual way to reduce howling. It is quite "size and position sensitive" and bigger magnet will kill its amplification, and smaller one will not have any effect for it. Anyway I found the way!
kodera2t wrote 07/16/2019 at 23:53 point
Thank you ;-)
Ken Yap wrote 07/16/2019 at 14:54 point
Hahaha, wonderful discovery. 👍
