Serial Binary Input Output And Operation
Enter some binary data. Transfer it to registers using patch-cables. Perform logical Operations on your data.
Public Chat
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This one uses shift registers. One of them is connected to a button and some leds so You can see and enter data in that particular register. There is one IO-register and 4 data registers, logical operations are performed on some of the storage registers. Data flow between the registers is controlled by the use of patch-cables.
Some 555-circuitry still needs to be setup to debounce the switches, but until then, an arduino should do the job. It also generates eight clock pulses for convenient register-to register transfer.
