Complete project overhaul
A project log for LoRaMessenger
LoRaMessenger is an off-grid chat between LoRa equipped ESP32 nodes with a simple wireless web interface.
nicholasNicholas 08/26/2020 at 17:250 Comments
The project has been completely redesigned and programmed from scratch.
After an immense amount of work I am finally ready to share a new base on which to build and improve this project, everyting has been correctly structured in order to make it easier to work and understand.
Major updates:
Full changelog:
The code is now in a relatively stable and usable state, all functions should work without too many problems. The routing part still needs to be fully tested as I haven't yet had the chance to test it with more than 3 nodes.
