Keywords: GSM, GPS, ELB-REV4 iSCADA, IR SENSOR, FIRE SENSOR, SMS, CLOUD, IoT, IIoT, internet of trains, railway safety, rail planning and scheduling, predictive maintenance, WSN, railway enhanced services, freight transportation, cyber security.
Introduction
The current network connectivity has increased over the last decade. An explosive growth in the number of computers and the need to share information has triggered the development of computer networks. Moreover, today’s application demands a wide variety of services from the network. There are many different classes of traffic on the network and each traffic type has different quality of service requirements. All these applications assume that the network will provide them with the best possible service it has to offer. To provide efficient service to each application, the network must always be operating efficiently. If there are any network failures, they must be rectified immediately. Network failures cause various losses such as efficiency and productivity, and eventually manifest as monetary losses to both the clients and network access providers.
Current network management systems help a network operator to detect and diagnose the problems in a network. However, as the complexity of today’s networks increases, there is a greater demand for the network to be self managing. A self-managing system should be capable of automatically detecting and diagnosing the network problems. A capability to repair ordinary faults would also be desirable in such systems. In this paper, we present an architecture for an intelligent network management system, called ExNet. We use expert system technology to add intelligence capability to commercially available network management systems.
The organization of the paper is as follows. In Section 2, we present the ExNet architecture. The component modules of the system are described here. Section 3 covers the implementation aspects of ExNet prototype. The various subsystems we have developed are described.  We conclude the paper in Section.
Architecture of an Intelligent Network Management System
Current network management systems are in general complex. They provide a lot of information and many different services. This has complicated the development of network management applications that utilize the services of these network management systems. The main goal of our effort is to apply expert system technology to reduce the severity of this problem and allow less experienced network operators to efficiently manage a large and complex computer network. Therefore, we need a management system which will analyze the network and its services, and properly manage its performance. It must be intelligent enough to diagnose most of the faults as they occur and have the capability to suggest corrective actions. Despite this complexity, the system should be easy enough to use. For this we use a web-based technology to provide the required user interface [BEGG 94]. The use of web-based technology enables us to provide a better graphical user interface to ExNet. Moreover, this allows users to have a global access to ExNet resources and information any time and from anywhere with Internet access.
Implementation
 We have developed a rule based expert system prototype, with rules for load monitoring and traffic routing. The Network Manager Interface has been implemented using web technology. Using the web-based interface we can perform basic network monitoring services. The network interface has been implemented using the IBM NetView/6000 for AIX Network Management System. The NetView/6000 is an SNMP based networking tool primarily meant for data collection in IP networks. It can also monitor various network parameters against previously defined thresholds and generate traps for network operators. We can use these traps to trigger other programs, such as the monitor.
Expert System Prototype
The prototype of the rule based ExNet is tested for a hypothetical network consisting of eight hosts and four gateways. Our aim is to simulate conditions for a real network and to route data between two given hosts. The system was built using CLIPS [GIAR 89]. The main tasks performed in this implementation were 1) monitoring congestion in the network by periodically gathering information on system status, 2) deciding whether the congestion has exceeded thresholds or not and what nodes are more congested than others, 3) choosing a new route for the data to be routed between the two hosts, and 4) suggesting a corrective action to the human manager.
The database containing the network information is provided by generating text files using IBM Net View/6000 for AIX. The monitor decides whether the problem in the current routing was related to performance or some system fault. Performance related problems include high latency, congestion or high system load. System faults include a crashed gateway or host. To determine a system fault, the monitor module would ping the host or gateway to inquire the status. The expert system analyzes the problem, requested more information from the network interface and after considering the alternatives decide on the new route to be implemented between the two given hosts. If there is a problem on an intermediate host/gateway, such as high load or too many users, the expert system would suggest a set of corrective actions to be taken.
Conclusion
We have presented two approaches to implement the expert system module of the ExNet prototype to achieve intelligent network management. These two approaches are rule-based and case-based expert systems. We have implemented the rule-based expert system in our prototype. It is efficient for problem solving in domains that are constant and where the expertise for solving the problems is relatively fixed. Unfortunately, today’s networks are dynamic with new components, new technologies, new protocols and new applications being introduced routinely. Case based reasoning approach provides an interesting approach to address these limitations. We are planning to develop an intelligent network management system using case-based reasoning and improve the web-based graphical user interface to support a wide range of control and management functions.
