My design is very simple I created a garbage vending machine in which if you will put garbage you will get money and those garbage can be sorted and used further on .The component which detects waste is a ldr any defect in light value updates the Arduino which complete a circuit which have a servo motor which rotates 180° each time updated launching a coin from stack holder in additional I attached a LCD screen giving instructions in a moving form.
Is that your machine in the gallery or another design? That looks like a can and bottle recycling chute in there, with a conveyer belt and probably a bar code reader. I don't believe you will be able to make a practical machine to take ANY garbage and recycle it. Contamination must be avoided.
Around here we already have RVMs and they accept only PET bottles, Al cans, and glass bottles. These are the materials that can be profitably recycled with RVMs. Other things like steel cans and plastic containers need industrial scale processing, and as much pre-sorting by the users as possible.
