• Stock replenished
    Beast Devices09/07/2019 at 16:42 0 comments
    The stock is finally replenished!
  • Samples sold out
    Beast Devices08/29/2019 at 23:09 0 comments
    The first samples were sold out quickly. More in stock will be available in the mid-September.
  • First samples for sale assembled
    Beast Devices08/28/2019 at 21:57 0 comments
    I have manually assembled the first couple of samples for sale on Tindie!
  • Finished case for a simple mini-power bank
    Beast Devices08/09/2019 at 23:35 1 comment
    I have finished the design of the lid for the case for the mini-power bank which can be used in small projects, where regulated voltage is not required.
    I have also tested out a concept of having the indication with LEDs through a thinned plastic. A near cut-out has 0.2mm thickness, while the rest of the lid has thickness of 2 mm. When there is no light source inside of the enclosure, the near cut-out is not visible from outside.
  • An enclosure for the charger and 500mAh LiPo
    Beast Devices07/31/2019 at 20:23 0 comments
    I have used Fusion 360 to make a quick enclosure for the charger and a 500mAh LiPo battery. Have made some renderings to show the progress. The outside dimensions of the enclosure are 55 x 35 x 10 mm. The design is prepared for a cover on the top, which will be held by two latches and two M3 screws, screwed directly in the plastic.
    Going to it print on my Ultimaker 3 soon.
  • Testing
    Beast Devices07/30/2019 at 20:49 0 comments
    I have soldered the wires from a brand new 500 mAh LiPo battery to the charger to make a first serious test. The internal resistance and high SoC put the charger in a constant voltage mode in about 10 minutes. I have measured the voltage across the battery (4.192V) to verify that it is not a thermal throttling.
    The reason for using USB-A to USB-C cable is because I don't have a USB power meter with USB-C connector. It is more handy to use USB power meter rather than measure the battery current with the multimeter. However, I have tested it with USB-C to USB-C cable as well, and it seems to work, since the charger gets warm.
    The next step is to make a simple enclosure, which integrates charger with the battery.
  • The first prototype is assembled
    Beast Devices07/11/2019 at 08:48 0 comments
    I have manually assembled the first prototype!
