On dying HC-SR04s
A project log for scooter
A little robot that scoots around
kyle-isomKyle Isom 07/22/2019 at 18:170 Comments
So it looks like these are *really* sensitive to voltage: anything over 5V causes them to die.
Scooter has a 6V power supply, which is the likely culprit for this.
It's a problem I've had with other things, so I've started designing a power distribution board based on LM-series voltage regulators; I want to be able to support much voltages than 6V, for example 6-AA packs (9V).
