Calibration Program Initial Results
A project log for Read Rope / Electronic Nerve
This is an open-source hardware project for a device that outputs a certain voltage depending on where the rope/wire is bent.
pablo-antonio-camacho-jrPablo Antonio Camacho Jr. 01/25/2020 at 19:400 Comments
I made a calibration program using Arduino that uses serial to make the arduino choose to do calibration or read values.
Code:
https://github.com/adct-the-experimenter/read-rope/blob/master/adc_code/arduino/read-rope-ADC/read-rope-ADC.ino
The calibration fixed problems caused by error between actual output voltage and expected output voltage.
Calibration is a step in the right direction.
However, improvements need to be made to the calibration program to fix sensing multiple bends.
The assumption that only 3 individual sections need to be calibrated since multiple bends are just a linear combination of the values of 3 individual sections is not working very well.
The program needs to spend more time finding the max value output when a complete bend is made.
