Now with Home Assistant control
A project log for LEGO Saturn V and Lunar Module Come to Life
Add some interactivity to the LEGO Apollo sets! Includes exhaust plumes, audio, a countdown timer and warning lights.
ben-brooksBen Brooks 02/23/2022 at 20:010 Comments
Since having originally created this project, I've discovered the amazingness that is Home Assistant.. I'm all-in on HA and am slowly including my homemade projects into it by adding the necessary code. I've uploaded the modified code to Github and renamed it since most folks probably won't care about this part.
If you aren't familiar with Home Assistant, check it out!
