- Robot 'Thor' rendering 09/25/2016 at 12:36 • 0 comments After the modification I made a render of my personal robot :) from the moment everything has been printed and assembled I will send everything to Gihub, all parts has to be firmly fitted with each other. There will be a step by step manual to build one for all.
next day printing some robot pieces
09/25/2016 at 11:40 •
0 comments
A new day, some new modified prints, made this one a little bit lower than the original to fit in my printerMade two pieces that can be shifted over each other and can be glued together
- Thor robotic arm 09/23/2016 at 20:48 • 0 comments As a team member of the 'Thor' project I am building one myself with some addons and little changes to print it on a smaller enviroment 3D printer. Everything will be find on github 'Thor' see AngelLM 'Thor' project for more info.The connector box addonFor manual teatching to position of the robot I worked out a hand controller with arduino one serial communication with the main controller arduino mega.For the moment I am building also a GUI controller to program and simulate 'Thor' from any platform with Unity.I just started to programming, follow me the comming days... weeks :)
