FIRST UPDATE 'THOR ROBO-GUI'
A project log for 'Thor' robot with addons and GUI
Thor robot based on the author AngelLM
dannyvandenheuveldannyvandenheuvel 11/19/2016 at 00:224 Comments
First update graphical GUI controller for THOR robotic arm. Still in progress... Inverse kinimatics build in.
Luka wrote 11/19/2016 at 18:27 point
I'm following this project for a while and often check for new logs. This one is excellent. For my final project I will create my own robotic arm prototype using similar components,also 3d print them, use arduino as controlor...etc, and this will be good base for it. Keep pushing!
dannyvandenheuvel wrote 11/19/2016 at 08:42 point
Thanks for the feedback, will be added to my todo list!
Olaf Baeyens wrote 11/19/2016 at 01:28 point
An other thing you may want to add (in the future) is a calibration mechanism. I am building my version but since I have issues with my printer my robot dimensions will be slightly different.
Olaf Baeyens wrote 11/19/2016 at 01:22 point
Keyboard shortcuts! Never forget about keyboard shortcuts!
You could program the numeric keyboard 0..9 for different views.  And maybe you could use Alt 0.. Alt 9 and Ctrl 0.. Ctrl 9 for movement.
