Controller board specification and software sources
A project log for PiXPi dslr camera controller
Modular and programmable DSLR camera trigger
krzysztof-krzeslakkrzysztof krzeslak 08/24/2019 at 18:090 Comments
Hello today I wanted share quick summary specification of current controller board design,
and as this project is meant to be opensource I want to share some sources today I Think both will be good summary for entry round of this contest :).
                                                            v0.9(current)controller version
Controller software:
https://github.com/krzysztofkrzeslak/pixpi-controller-app
it's Python app sources which is running on controller.
Hardware specification:
1 x Optoisolated camera port(2,5mm jack) for camera focus/wake and trigger
2 x Optoisolated Flash port(3,5mm jack) for flash triggering
3 x module port, which can be used in following modes:
      Port Red: Input, Output, Com(1-wire), Pulse
      Port Green: Input, Output, Pulse
      Port Blue: Input, Output, Pulse
      Each port has 3 pins: Signal, 12V, Gnd
      Ports connector fits standard servo connectors
8 x Gpio pins
1 x mini-B usb connector for accessing Linux command line/serial console.
1 x 1,27mm 6pin SPI connection for complete flash writing(unbricking, bootloader change, etc. )
1 x DC jack for 12v supply (should be tolerant up to 22v)
2 x status led: supply, ready
3 x port status led
1 x Buzzer for state indication
Powered with opensource VoCore2 system on module (https://vocore.io)
Which provides:
- Mediatek MT7628, 580 MHz SoC
- Memory(ram): 128MB, DDR2
-  Flash: 16MB
- Running under Linux(OpenWrt) control.
It's also fully OpenSource: Complete specifications and sources available on: https://vocore.io/v2.html
