07/18/19 - Converting Bitmap Images into 8bit arrays
A project log for My attempt at an ESP-NOW Mesh
Designing a custom mesh for sensors, home automation and remote controlling using Espressif's ESP-NOW
david-mDavid M. 07/31/2019 at 18:420 Comments
I found a way to convert bitmap images into an 8bit format, but 16bit images prove to be a challenge. The only way I was able to display a 16bit image so far is by converting one manually.
I found a couple tools to help me convert bitmaps: "lcd-image-converter" and "LCDAssistant". The lcd-image-converter, however, looks to be more capable, so I will try to figure it out.
Fig. 4 - lcd-image-converter main window
