3D model of the enclosure
A project log for Data logger device for DM3058 digital multimeter
Small device that connects to serial port of DM3058 bench top multimeter to retrieve and log measurements
kristsKrists 06/20/2020 at 15:520 Comments
3D model and print of the enclosure for the device is ready. Small changes should be made but overall everything fits together nicely. One catch, though, is that ABS material used for print is quite translucent and backlight from LCD screen illuminates through the material. This could be fixed by using additional light blocking insert or making front part thicker and having less translucent material.
Model was designed using FreeCAD and consists of two parts bolted together.
