The two separate boards are populated by:
Mainboard: a VoCore2 board, 2.43mm pin headers a minipci-e connector with standoffs.
MiniPCI-e board: n-fuse LoRaWan gateway, should also be compatible with RAK concentrator.
POE board: SiLabs Si3404 PoE with accompanying passives.
