Power intake socket mounted.
Power distribution wiring harness complete.
USB hub attached to harness and mounted.
Motherboard mounting plate attached.
PS/2 Converter mounted.
Power switch mounted and partially wired.
What's left?
I'm waiting for my iron to cool so I can swap tips -- I have a super tiny tip that I'm going to use to tack down the power switch wires. I don't want to screw up another motherboard, they're expensive and getting hard to find (cuz they're also an older model).
Then it's a matter of mounting the heatsink and mobo, and cutting holes for the audio and LCD cables, and mounting the screen -- yes, I decided to attach the screen from Scrappy to this monstrosity -- because, hey, why not...
A picture of the delightful mess RN...
...yeah...
