Tick tock, tick tock ... hickory dickory dock!
A project log for Stalking the Big One
Adapting an existing code base used for music transcription and spectrum analysis to forecast the near exact time of a major earthquake.
glgormanglgorman 08/25/2019 at 10:340 Comments
Here it is August 25, 2019 and I still don't have live P2 hardware to port my code base over to.  Still I venture on, and will continue to work with Windows 10/Visual Studio and the P1 hardware, as well as conducting experiments with the P1 stuff that I have so that when I do get the final hardware - it will be possible to simply configure the filtering and processing algorithms by, for example, simply describing the filter tree in XML or maybe in SCRATCH!  (even if that is a bit far out there!)
