​ Controller Enclosure
A project log for Just Another Dust Collector Controller
Automatically detects when a blower gate is opened and turns on the collector motor
jasonJason 09/04/2019 at 23:420 Comments
With the Bud Industries DCH-11923 enclosure arriving; the first round of layout testing has begun.  Nothing will be set in stone until the PCB arrive so a proper fit can see seen.  But the mock-up seems to fit correctly! :D  System enable/disable (stop) may be mounted outside of the enclosure door but in a spot to not touch the high voltage wiring.
