i found this in the background somewhere on the internet.
and indeed it is faster . i had to correct the 1L to 127L as explained in the article bellow with some users having issues with it originally. it however has an error rate of up to 8% but for whole numbers <6%
float fastsqrt(float val) {
long tmp = *(long *)&val;
tmp -= 127L<<23; /* Remove IEEE bias from exponent (-2^23) */
/* tmp is now an appoximation to logbase2(val) */
tmp = tmp >> 1; /* divide by 2 */
tmp += 127L<<23; /* restore the IEEE bias from the exponent (+2^23) */
return *(float *)&tmp;
this code makes error rate with whole number <3%
float invertDivide=0.66666666666 ;// ~1/1.5 rounded down to float precision single float
val*=0.22474487139;
long tmp2 = *(long *)&val;
tmp -= 127L<<23; //* Remove IEEE bias from exponent (-2^23) */1065353216
tmp2 -= 127L<<23; //* Remove IEEE bias from exponent (-2^23) */1065353216
temp2=tmp>>20;//any time number is negative it is more error rate
tmp = tmp >> 1; //* divide by 2 *
tmp2 = tmp2 >> 1; //* divide by 2 *
temp=tmp;//any time number is negative it is more error rate
// if (tmp <0) tmp=tmp+1L<<22;//invert -10066330
//23-8bits
temp2=tmp>>23;//any time number is negative it is more error rate
//when tmp=0 error rate is high also -2,-1
tmp +=1065353216; /* restore the IEEE bias from the exponent (+2^23) */
tmp2 +=1065353216; /* restore the IEEE bias from the exponent (+2^23) */
float offset=*(float *)&tmp2;
val= *(float *)&tmp;
return (val+offset)*invertDivide;
first version <4.3% numb range 0 to 100
2 1.414214===== 1=1.5 variation % = 4.289323
version with offset <2.7% numb range 0 to 100
2 1.414214===== 1=1.466326 variation % == 2.605647
but it gets tricky for the numbers with digits before 0.
original has an error rate of >24% for below as new version is 11.5%
0.01 0.100000===== 1=0.101153 variation % == 11.530593
so some work needs to be done to make it adjust to the precision of the float
i'll play around with it more. it seems something that is useful for some people, but i would like precision to be closer to 0.5% to 1% or even better.
I'll update if i get something faster or better.....
