A project log for Bot-thoven: A Robot Musician
Designing a Servo Motor Based Mallet System to Generate Musical Expression in Instrument Playing Robots
jason-pJason P. 10/04/2019 at 14:570 Comments
Plan
This week, I finished my Project Proposal and created a preliminary design for the servo-mallet system I will be using to conduct my project.
Procedures
I looked into examples of xylophone-playing robots made by other individuals to see how they were able to attach a mallet to a servo.
Progress
My project proposal is available here
The image above shows the proposed design of my xylophone-playing robot. The mallet will be attached to a long servo horn and fastened using a zip tie. I decided to vary the rotation degrees per second on the servo motor to achieve different dynamics for my xylophone robot.
Problems
I will need to create prototypes of the servo-mallet system and test it on a xylophone key to see if the design functions and is stable.
Following my proposal presentation, I received feedback that I should find outside sources of support who I could reach out to for advice on my project. I will need to look into possible researchers in the field of robotic instruments.
