Infrared range
A project log for Time Blaster
IR blaster to be used with the Fri3dcamp 2020 badge
hans-poldershans polders 03/11/2020 at 16:460 Comments
We succeeded in transmitting data over a range of 32 meter.
Aiming the blasters became impractical at a range of about 25 meters.
We tested outside in the dark to eliminate interference from the sun.
Technical specs:
To send data we turn the 38 kHz carrier frequency on and off.
The duration of the on + off length determines the type of signal (start, 0, 1, stop)
time on in ms (1000 Hz)time off in ms
Start816
logical 111
logical 013
Stop11+
This is loosely based on the NEC IR protocol.
sending one bit takes 2 ms on average, excluding the start and stop bit.
