DAC on the Z80_PSoC
A project log for 3-Chip Z80 Design
Combining a Z80 retro design with a modern PSoC CPU.
land-boardscomland-boards.com 10/27/2019 at 11:300 Comments
Going to play with the DAC on the Z80 PSoC. Dropped the WaveDAC8 symbol on the schematic.
PSoC Pinout
Hooked up to PSoC pin 95.
Added code:
void init_DAC(void)
    WaveDAC8_Start();
Looked at R4 and saw sine wave.
Here's the DAC handler.
uint8 dacState;
uint8 outDataDAC;
uint8 inDataDAC;
// void init_DAC(void) - Initialize the DAC
void init_DAC(void)
    WaveDAC8_Start();
    outDataDAC = 0;
    inDataDAC = 0;
// void writeDAC(void) - Write to the DAC data
void writeDAC(void)
    outDataDAC = Z80_Data_Out_Read();
// void readDAC(void) - Read the DAC data
void readDAC(void)
    Z80_Data_In_Write(outDataDAC);
    ackIO();
// void readStatDAC(void) - Read the DAC Status
    Z80_Data_In_Write(dacState);
    ackIO();
// void writeCmdDAC(void) - Write the DAC command
//  0 = Turn off DAC output
//  1 = Turn on DAC output
    dacState = Z80_Data_Out_Read();
    if (dacState == 0)
        WaveDAC8_Stop();
    else if (dacState == 1)
        WaveDAC8_Start();
    ackIO();
Here's the output,
1 KHz. Matches the setup in PSOC Creator.
