Second experiment with known part numbers
A project log for Which colours are LEDs sensitive to ?
Measurement of the spectral sensitivity of several LEDs
matthias-kochMatthias Koch 01/02/2020 at 16:100 Comments
Time for a second revision, this time with known part numbers:
This is the list of LEDs used, from left to right:
  #  Colour  Reichelt part     peakwl Vf min  typ  max     Crystal material    Angle   Brightness  Manufacturer part number          Notes
  0    IR    SFH 4346            950 nm   -   1.6  1.9  V   ?                   20°                Osram OS     SFH 4346             Tinted
  1    IR    SFH 4356P           860 nm   -   1.7  2.0  V   ?                   20°                Osram OS     SFH 4356P            Tinted
  2    red   RND 135-00006       700 nm  1.8   -   2.6  V   GaP                 40°      10 mcd    RND          RND 135-00006        Tinted
  3    red   LED 3-3500 RT       660 nm   -   1.85 2.5  V   GaAlAs              50°    2300 mcd    Kingbright   L-934SRC-J4
  4    red   LED 3-4500 RT       660 nm   -   2.1  2.5  V   AlGaInP             34°    4500 mcd    Kingbright   L-7104SRC-J4
  5    red   EVL 264-7SDRC       650 nm  1.7  2.0  2.4  V   AlGaInP             40°     100 mcd    Everlight    264-7SDRC/S530-A3
  6    red   KBT L-7104SURC      640 nm   -   1.9  2.5  V   AlGaInP on GaAs     34°    2500 mcd    Kingbright   L-7104SURC-E
  7    red   KBT L-7104SEC-H     635 nm   -   2.2  2.8  V   AlGaInP             34°    1000 mcd    Kingbright   KBT L-7104SEC-H
  8    red   VIS TLHR 4900       635 nm   -   2.0  3.0  V   GaAsP on GaP        16°      13 mcd    Vishay       TLHR 4900
  9    red   SLK 3MM RT          627 nm   -   2.0  2.5  V   GaAsP on GaP        50°      60 mcd    Kingbright   L-934EC
 10   green  WUE 151034GS0300    525 nm   -   3.2  3.8  V   InGaN               30°   10000 mcd    Würth        151034GS03000
 11  orange  LED 3-7800 OR       611 nm   -   2.2  2.8  V   AlGaInP             34°    7800 mcd    Kingbright   L-7104SEC-J4
 12  orange  LED 3-3000L ONG     605 nm  1.6  2.0  2.4  V   ?                   20°    3000 mcd    Lucky Light  LL-304UAC2E-4AC
 13  yellow  LED 3-2800 GE       590 nm   -   2.0  2.5  V   AlGaInP             34°    2800 mcd    Kingbright   L-7104SYC-J3
 14  yellow  NTE NTE30032        592 nm   -   2.0  2.4  V   AlGalnP on GaAs     10°    2500 mcd    NTE          NTE30032
 15  yellow  LED 3-1300 GE       595 nm   -   2.0  2.4  V   AlGaInP             50°    1300 mcd    Kingbright   L-934SYC
 16    ?     VIS TLHY 4205       585 nm   -   2.4  3.0  V   GaAsP on GaP        22°      20 mcd    Vishay       TLHY 4205            Tinted, does not light up
 17 yl-green KBT L-7104MGC       574 nm   -   2.1  2.5  V   AlGaInP             34°     700 mcd    Kingbright   L-7104MGC
 18 yl-green KBT L-7104GC        565 nm   -   2.2  2.5  V   GaP                 34°      60 mcd    Kingbright   L-7104GC
 19   green  LED 3-14000 GN      520 nm   -   3.2  4.0  V   InGaN               34°   14000 mcd    Kingbright   L-7104ZGC-G
 20    red   WUE 151034RS0300    628 nm   -   2.0  2.6  V   AlGalnP             30°    2600 mcd    Würth        151034RS03000
 21   green  EVL 204-10 UBGC     502 nm   -   3.5  4.3  V   InGaN on SiC        20°      50 mcd    Everlight    204-10 UBGC/S400-A6
 22 trqouise RND 135-00151       500 nm  2.6  3.2  3.6  V   ?                   30°    8500 mcd    RND          RND 135-00151
 23   blue   LED 3-3700 BL       465 nm   -   3.3  4.0  V   InGaN               20°    3700 mcd    Kingbright   L-7104VBC-D
 24    IR    BPW 34                                         Si                  65°                Vishay       BPW34                PD 600-1050 Peak 900 nm
 25   blue   LED 3-2000 BL       465 nm  2.9  3.3  3.6  V   InGaN               30°    2000 mcd    ?            L-314BC-A3
 26   blue   LED 3-3000 BL       458 nm   -   3.2  3.7  V   InGaN               20°    3000 mcd    Kingbright   L-7104QBC-G
 27  blueish EVL 1254UBC         428 nm  3.0  3.8  4.5  V   GaN on SiC          40°     400 mcd    Everlight    1254UBC
 28    UV    LED LL 3-120 VI     400 nm  2.8  3.2  3.8  V   InGaN               20°     120 mcd    LuckyLight   LL-304UVC4B-Q5D
 29   green  KBT L-7113ZGC       515 nm   -   3.3  4.1  V   InGaN on Sapphire   20°   14000 mcd    Kingbright   L-7113ZGC            5 mm
Sensitivity measurements were done exactly as in the first revision of the experiment, as explained in the Project Details. As I changed lab in the meanwhile, I cannot use the spectrometer anymore, therefore no measurements of the emission spectra this time. The peaks drawn in red denote the peak wavelength given in the respective datasheets.
All parts were sensitive to direct sunlight, but with varying orders of magnitude of their discharge times. Therefore, some parts are not sensitive enough for this experiment, other parts are highly sensitive, but for wavelengths outside of the range of my monochromator.
Data is sorted for emission wavelength.
Infrared:
BPW34 is the same photodiode as in the first run of the experiment, which is sensitive to the complete visible range. Datasheet claims best sensitivity between 600 and 110 nm, with a peak at 900 nm.
The flicker artifact is quite strong in this measurement, but the general shape of the sensitivity is clearly visible and comparable to the first run of the experiment.
These two infrared LEDs in tinted housing are sensitive to wavelengths > 700 nm, mostly outside the range of my monochromator. On the first experiment, I used IR LEDs in clear housing, which had a broader sensitivity, extending in the visible range.
Visible red:
This one is quite insensitive, no sensitivity data could be measured.
Sensitive for green to red, with a distinctive photo current.
03 and 04 show very similiar sensitivity.
This red LED can see blue to red light, with a low photo current.
Similiar to 05, but with a larger photo current.
Sensitive for green to red, strong photo current.
Sensitive for green to red.
The most narrow bandwidth red LED in this experiment, sensitive for orange and red. There is a small additional peak at green wavelengths, but with much lower sensitivity.
Sensitive for yellow-green to red.
Visible orange to yellow:
Sensitive for yellow-green to orange.
Large bandwidth from blue to orange.
Sensitive for blue to yellow, but with an interesting shape of the sensitivity spectrum. Maybe this is a mixed material crystal ?
Similiar to 14, but with a less sharp peak.
This LED was sensitive to direct sunlight, but did not light up with 3.3V, which denotes an unusual high Vf for a yellow LED. Perhaps this is an indirect bandgap crystal, sensitive to ultraviolet only ? I had a similiar case in the first run of the experiment, in which a red LED was UV sensitive, but due to lack of data, this is an hypothesis only. Do not use this one for now, its strange.
Visible yellow-green to ultraviolet:
Sensitive for blue to green.
Both yellow-green LEDs 17 and 18 are direct bandgap semiconductors as all LEDs shown before, which are sensitive to their own emission. 17 has narrower bandwidth and a higher photo current than 18, otherwise they are similiar.
Sensitive from UV to blue-green. From now on, the LEDs are indirect bandgap semiconductors, which are not sensitive to their own emitted colour.
Similiar to 10, but with a larger photo current.
This is a 5 mm LED, because the peak wavelength of 515 nm was not available in 3mm housing at Reichelt. Its sensitivity is similiar to 19.
Sensitive for UV to blue only, narrow bandwidth, low photo current
Emitting a very nice colour looking turquoise, this LED is sensitive from UV to blue-green.
Sensitive for UV to deep blue.
This blue LED is too insensitive for measurement.
Sensitive for UV to deep blue, with (small) overlap of its peak emission wavelength with sensitivity spectrum, which is uncommon for blue LEDs.
Deep-blue LED, no sensitivity found, despite being sensitive to sunlight. Deep UV-sensitive, probably.
UV-LED, emission peak wavelength close to the border of the monochomator. Its sensitivity must be deep in UV.
