Log 3
A project log for SMS Garage Alert system using an Ultrasonic sensor
ESP8266 SMS Garage Alert system using a RCW-0001 Micro Ultrasonic Sensor and a Webhook (IFTTT.com and IFTTT android app)
paul-gPaul G. 11/13/2019 at 18:570 Comments
And the testing phase is over! I've implemented the code from Log 2 into my sketch. You can also take a look at the code in the section Project code. The new sketch can be downloaded in the files section. The D1 Mini should consume less power now, when the watchdog isn't active. I will measure the actual currents on the weekend, when I'm less tired.  I'm really busy at the moment, because I'm doing an advanced training in the field of geoinformation systems (GIS) so please bear with me.
