IR Receiver Daughter Card for IRShine
This daughter card further expands the capabilities of IRShine by adding a universal IR receiver and an optional temperature sensor
Public Chat
IR Receiver Daughter Card for IRShine with optional temperature sensor
This daughter card further expands the capabilities of the IRShine by adding a universal IR receiver and an optional temperature sensor. The card is extremely small, fully integrated with the mainboard and fits perfectly into the IRShine plug box.
The daughter card is compatible and can mount ANY Vishay Heimdall IR receiver for carrier frequencies of 30, 33, 36, 38, 40 and 56 kHz and it can support any IR protocol. The optional temperature sensor is a DS18B20 and can be used to monitor the temperature inside the plug box.
x-zip-compressed - 27.60 MB - 10/20/2019 at 09:08
Download
x-zip-compressed - 57.65 kB - 10/20/2019 at 09:08
Download
x-zip-compressed - 27.66 kB - 10/20/2019 at 09:08
Download
  • 1
    Step 1
    This daughter card is compatible and can mount ANY Vishay Heimdall IR receiver for carrier frequencies of 30, 33, 36, 38, 40 and 56 kHz and it can support any IR protocol. The optional temperature sensor is a DS18B20 and can be used to monitor the temperature inside the plug box.
    The daughter card uses ESP8266 GPIO12 for the IR receiver and GPIO13 for the temperature sensor
    Bill of materials:
    • U1 - ANY Vishay Heimdall IR receiver (see all models here)
    • U2 - optional DS18B20Z+
    • R1 - 100ohm 1% 1/8W SMD 0805
    • C1 - 4.7uF X7R SMD 0805
    • R2 - optional 4.7K 1% 1/8W SMD 0805
    • C2 - optional 0.1uF X7R SMD 0805
    • P1 - Pin strip 2.54mm 8 pins
View all instructions
