New look :P
A project log for uLogger UART/SPI/CAN/I2C multivoltage converter
Universal logging platform for many infrafaces with WiFi and Bluetooth
rafal-woloszynRafal Woloszyn 07/20/2023 at 21:200 Comments
Hi guys,
With a suggestion from the designer (@Marek) uLogger have a new black solder mask PCB.
It looks awesome!!!
We are updating the firmware to clean up all the PCB bugs and hacks we introduced to test the latest prototypes.
The ST32 firmware is under heavy testing. The UI web part for the ESP32 module is not done yet. It supports just simple monitoring without the possibility to configure and change anything.
We also decided that a mobile application for Android/iPhone could be useful as well so I started to develop one with the Flutter framework.  Soon I will share screenshots or even Play Store/Apple Store links.
ahh, I would forget that logger also have a proper plastic enclosure where it fits as it should. Let's wait for new pictures when I receive fully prepared, CNC drilled enclosures with PCB inside.
P.S. If you are of any chance interested in that project just like it here on Hackaday or drop me a DM message. Sharing with this community helps to motivate us ;) Thanks !!
