The X/Y carriage rails
A project log for MechaCore - Railcore Inspired 3D Printer
I started to build a RailCoreII ZLT printer, but decided to give it a once-over and fix/update everything I don't like, keeping what works.
patrickPatrick 12/06/2019 at 04:290 Comments
The 3 rails that make up the RailCore X/Y stage are minimalistic, but still have their challenges. The challenges here are as follows
I've considered putting the X rails on top of the Halo. The challenge is all the belt pulleys would have to lift off the halo to clear everything. Not a big deal, except the stepper motor won't really work being mounted on the halo, as the motor shaft is too short and you don't really want to put that much of a cantilever'd load on the motor shaft.
Railcore gets away with a single block on each X rail. They do use the long block.
One idea I'm considering is using 2 short blocks on each X rail. This would add about $40 to the total build cost (Misumi high-temp SSE2BST13-395).
Alas, no decisions yet. At this point, I have things I want to consider, but will be moving on to the Y Carriage.
Lots of decisions to make here, which extruder, hot end, height sensor, etc.
