FRC miniPneumatic Control
A FRC miniPneumatic control assembly
Public Chat
FRC Mini Pneumatic control
Each season, FIRST Robotics Competition teams receive Kits of Parts (KoP). The KoP is not designed to be a "bolt together" solution to play the game, but is a starting point, containing mostly donated components from Suppliers across multiple industries.
FRC KOP
This project is based on that statement utilizing Automation Direct NITRA mini pneumatics. These components are not in the KoP for 2020, but can be obtained thru vouchers or ordering direct.
Automation Direct
FRC 2019 First Robotics : Use Mini-Pneumatics to Improve your Design
pneumatics-manual.pdf
FIRST Robotics Competition Pneumatics Manual
Adobe Portable Document Format - 1.41 MB - 11/18/2019 at 01:11
Preview
Download
  • 1 × HVU14-3 - NITRA pneumatic Inline manual shutoff valve NITRA pneumatic push-to-connect fitting, inline manual shutoff valve, 3-way, technopolymer body, (2) 1/4in tube connection(s).
  • 1 × PGU14 - NITRA pneumatic Inline pressure gauge NITRA pneumatic push-to-connect inline pressure gauge, technopolymer body, 1/4in tube inlet(s), 1/4in tube outlet(s), 0-170 psi range.
  • 1 × TU14 - NITRA pneumatic U-tube NITRA pneumatic U-tube, polyamide, 1/4in. For use with push-to-connect fittings.
  • 1 × FBKT - NITRA pneumatic mounting bracket NITRA pneumatic mounting bracket, plated steel. For use with push-to-connect fittings.
  • 1
    NO INSTRUCTIONS
View all instructions
