V4.0 Beta2, With OTA, but no face recognition
A project log for $7 ESP32 CAM example expanded
A proper implementation of a ESP32 CAM webserver; based on the Espressif example, but extended for real-world use
owenOwen 07/06/2021 at 10:370 Comments
I've got a new beta release out on Github for V4.0 of this project, The principal change is that I have removed all the face recognition code/UI, resulting in a much smaller codebase that allows for Over The Air updating (OTA). Super handy if you want to mount the camera in an inaccessible location.
* The programming instructions have changed - The boards manager entry for the AI-Thinker board does not use OTA compatible partitioning, so you need to choose a Generai ESP32 dev board entry, select the correct partitioning, and enable PSRAM in the GUI. See the updated README
* There are some other fixes for Video quality issues that should be useful
* The OTA update can be secured with a password to stop the unit being hijacked
* There is a fix to allow using the ESP Arduino IDE Core v2.x (currently in beta) and I have been testing with this for a few weeks now, no issues seen. If anything the performance and video quality are better.
