This widget will calculate a temperature reading using a thermistor. This temperature will be used to determing the duty cycles of red, green and blue LED's in a single RGB LED. The software will mix red, green and blue in order to show the color of the ambient temperature. 0F is pure blue, 50F is pure green & 100F is pure red. All temperatures will be mixtures of either red/green or blue/green.
