Getting To Ready To Code
A project log for Electronic Load 3.3V-16V 1A
Electronic load that supports 3.3V-16V at 1A of current. Equipped with keypad, LCD, rotary encoder, STM32 Microcontroller and more!
schwarzrmsuschwarzrmsu 12/12/2019 at 00:340 Comments
Getting started with the software portion of the project proved to be quite difficult.  I had to learn which tools and software to use in order to do so.  Below is a breakdown of my selections along with how you can get started yourself if you wish to use a similar tool chain.
Programming Tool:
I chose the STLINK-V3
https://www.st.com/en/development-tools/stlink-v3set.html
This seems to be a very versitile tool.  I plan on using the following pins to interface with my board:
  1. VCC (3.3V)
  2. CLK
  3. GND
  4. DIO
  5. NRST (Forgot to route, going to need to solder wire to make connection [TP 47])
Choosing an IDE:
Choosing an IDE seemed to be the most difficult decision.  Through a bit of research I decided on using the following tools:
Powering Board:
I simply plugged in a 12V center positive plug pack into the power connector.  You could power up using a current limited supply just in case, but I felt confident so I plugged directly into wall.
You should see the back light on LCD power on:
You should also be able to measure 3.3V on the voltage regulator:
Connecting Board To Programming Tool:
Next I connected the programming tool to my board.  You will need to make the following connections:
  1. VCC (3.3V)
  2. CLK
  3. GND
  4. DIO
  5. NRST (Forgot to route, going to need to solder wire to make connection [TP47])
I plan on switching to the STLINK-V3 main 14 way connector for future revisions in order to simplify the programming tool connections.
Communicating With Microcontroller:
With everything plugged in.  I opened the STM32CubeProgrammer, crossed my fingers and hit connect:
I succesfully connected to the microcontroller which means I am ready to start programming.
