Design
As mentioned in the introduction, the UWB Feather consists of an ATSAMD21 ARM Cortext M0+ for the brains and a Decawave DWM1000 module for the ultra-wide band wireless, in the feather form-factor. The design is relatively simple consisting of 20 BoM items on a 2-layer PCB. Pinout is Adafruit M0 Feather compatible
LiPo charging is handled by the MCP73831 single-cell, fully integrated charge management controller. Battery voltage can be monitored on D9, however is access to all the IO is required, JP1 can be cut to free up this pin. 3.3 volt regulation is preformed by the AP2112K-3.3 low dropout linear regulator, providing up to 600mA.
Pinout is fully compatible with the Adafruit M0 feather line for easy code portability. The DWM1000 IO lines are connected to the SPI bus and digital pins 2, 3 & 4 for RST, IRQ & SPI_CS respectivly (which are not exposed via the header). D13 is also connected to the onboard LED, as is standard among many Arduino-compatible boards.
Programming can be preformed over the SWD header or via USB if loaded with a corresponding bootloader such as the uf2-samdx1 from Microsoft. See firmware for more.
Spot the issue
Note on V1.0: There is an issue with the USB-C connector on version 1 of this board. The footprint I used did not include the cutout required for the cutout mounting method of this component.
Version 1.1 will include a fix for this as well as adding a micro-b connector for those who want it. See version 1.1 considerations below.
The DWM1000 has a One Time Programmable (OTP) user programmable memory for storing calibration information (see 1.6 in the datasheet). To program this region the VDD3V3 pins may need to be raised to 3.8 volts temporarily. To do this JP2 can be cut and a separate power supply can be connected to selectively boost the power to the module.
Version 1 Board Renders
Bill of Materials
BoM items are all available from DigiKey and are plentiful in supply. Total BoM cost was $60 AUD for 1 quantity, however further optimization can shave a few dollars off this.
CSV version of this table can be found in the project repository.
Manufacturer Part NumberManufacturerDigi-Key Part NumberCustomer ReferenceQuantityDescription
DX07B024JJ3R1600JAE Electronics670-2963-1-NDJ11CONN RCP USB3.1 TYPEC 24P SMD RA
S2B-PH-SM4-TB(LF)(SN)JST Sales America Inc.455-1749-1-NDCN11CONN HEADER SMD R/A 2POS 2MM
KMR241GLFSC&K401-1431-1-NDSW11SWITCH TACTILE SPST-NO 0.05A 32V
AP2112K-3.3TRG1Diodes IncorporatedAP2112K-3.3TRG1DICT-NDU41IC REG LINEAR 3.3V 600MA SOT25
MBR120VLSFT1GON SemiconductorMBR120VLSFT1GOSCT-NDD21DIODE SCHOTTKY 20V 1A SOD123FL
ATSAMD21G18A-MUMicrochip TechnologyATSAMD21G18A-MU-NDU11IC MCU 32BIT 256KB FLASH 48QFN
20021221-00010C4LFAmphenol ICC (FCI)609-3700-1-NDJ41CONN HEADER SMD 10POS 1.27MM
DWM1000Decawave Limited1479-1002-1-NDU31RF TXRX MODULE 802.15.4 CHIP ANT
MCP73831T-2ATI/OTMicrochip TechnologyMCP73831T-2ATI/OTCT-NDU21IC CONTROLLR LI-ION 4.2V SOT23-5
RC0603FR-075K1LYageo311-5.10KHRCT-NDR1, R2, R63RES SMD 5.1K OHM 1% 1/10W 0603
SML-D12D8WT86Rohm Semiconductor511-1577-1-NDD11LED ORANGE DIFFUSED 0603 SMD
150060BS55040Würth Elektronik732-12013-1-NDD51LED BLUE DIFFUSED 0603 SMD
RC0603FR-071KLYageo311-1.00KHRCT-NDR41RES SMD 1K OHM 1% 1/10W 0603
RC0603FR-07100KLYageo311-100KHRCT-NDR5, R32RES SMD 100K OHM 1% 1/10W 0603
TMCJ0J106MTRFVishay Sprague718-2355-1-NDC5, C7, C83CAP TANT 10UF 20% 6.3V 0603
RC0603FR-0710KLYageo311-10.0KHRCT-NDR101RES SMD 10K OHM 1% 1/10W 0603
TMCJ1C105MTRFVishay Sprague718-2362-1-NDC1, C4, C6, C94CAP TANT 1UF 20% 16V 0603
RC0603FR-07330RLYageo311-330HRCT-NDR91RES SMD 330 OHM 1% 1/10W 0603
CC0402FRNPO9BN150Yageo311-1642-1-NDC2, C32CAP CER 15PF 50V C0G/NPO 0402
FC-135 32.7680KA-A0EPSONSER4077CT-NDY11CRYSTAL 32.7680KHZ 12.5PF SMT
Hardware Version 1.1 Considerations
There are a number of changes required for a board that would be put into production as nobody gets it right the first time, every time. So here’s a list of changes required:
Assembly
With only 20 BoM items and most components being no smaller than 0603 (the 2x crystal capacitors were 0402) , hand assembly of this board was easy. I had the PCB and solder stencil manufactured by JLCPCB in matte black with ENIG surface finish.
Total cost for 5 boards (although 10 had no price difference) and stencil was $68 AUD, however $42 of that was shipping. First time ordering from JLCPCB and boards were of very high quality with nice finish.
Firmware
Firmware can be loaded over the SWD connector using a programmer such as the J-Link from Segger. Shown above is the J-Link EDU Mini. To start programming the board, we need to load our bootloader then set up our tool chain.
Programming the bootloader
I’ll be using Atmel Studio for flashing the bootloader. To do so, plug in the J-Link and open Atmel Studio. Then select Tools > Device Programming. Under Tool select the J-Link and set Device to ATSAMD21G18A then click Apply.
Connect the J-Link to the feather SWD header and apply power either over USB or via the battery. Once connected, under Device Signature click Read. The Device Signature and Target Voltage text boxes should propagate accordingly. If they do not check the connections and try again.
To flash the bootloader we first need to disable the BOOTPROT fuse. To do this select Fuses > USER_WORD_0.NVMCTRL_BOOTPROT and change to 0 Bytes. Click Program to upload the changes.
Now we can flash the bootloader by selecting Memories > Flash and set the location of the bootloader. Ensure Erase Flash before programming is selected and click Program. If all goes well D13 on the board should begin to pulse.
Now you’ll need to set the BOOTPROT fuse to the 8kB bootloader size. To do this select Fuses > USER_WORD_0.NVMCTRL_BOOTPROT and change to 8192 Bytes. Click program to upload the changes.
Now that the bootloader has been flashed D13 should be pulsing and if plugged in over USB, a mass storage device should appear. This is where UF2 files can be uploaded for programming the board.
Flashing firmware with PlatformIO
Firmware can be uploaded over the UF2 protocol or directly via the SWD interface. Here we’ll be using PlatformIO for its ease and simplicity. To get started create a new PIO project and select Adafruit Feather M0 as the target board. When uploading over SWD with a J-Link set the upload_protocol in platformio.ini as shown below.
[env:adafruit_feather_m0]
platform = atmelsam
board = adafruit_feather_m0
framework = arduino
upload_protocol = jlink
Now you can program the board with the simplicity of the Arduino framework.
Flashing the Anchor
The DWM1000 modules can be configured to be anchors or tags. Generally anchors are kept at known static locations and tags use anchors to get a relative position to them. To test the DWM1000 module you can upload the DW1000-Anchor example from the GitHub repository.
To flash this program with PlatformIO, from PIO Home, select Open Project then find the location of the DW1000-Anchor folder in the GitHub repository. Then click the PIO upload button and it will automagically find the attached debug probe (ensure it is connected and the board is powered).
The tag firmware will need to be uploaded to another board. Then the result can be viewed in a serial terminal.
Going further
Further improvements to this project will include development on a new DW1000 library, V1.1 board changes other projects that utilize this ranging technology. If there is sufficient interest I will consider manufacturing and selling these boards.
Thanks for reading. Leave any thoughts or criticisms in the comments below.
