Added all necessary project files for building the load!
A project log for Active electronic load
This project contains all needed files (hard- and software) to build an accurate and fast electronic load with hobbyist friendly components.
abaumgartnera_baumgartner 02/17/2020 at 14:350 Comments
Hello there!
Again some good news:
You can find all needed files for the software part including workspace of the microcontroller program (code composer studio from TI) and the Visual studio project to run/adapt the GUI on your PC.
Also the schematics and the PCB of the hardware is uploaded!
Very important:
All files of the project (including hard- and software) are published with the GPLV3 If you are unsure about your permissions, check https://www.gnu.org/licenses/gpl-3.0.html.
(If you find any mistakes in the licensing of this project, please tell me. I will try to correct this.)
After grading is completed, also the written part of this thesis will be uploaded to this project page.
