So the solder paste dispenser is finally ready for daily use and tested.
In normal mode:
- middle button pulls (retracts) the paste with maximum speed while the button is pressed
- right button pushes the paste (first with maximum speed for retract duration and after that with user defined speed), when released it immediately retracts (pulls) the paste for user defined time.
Other modes are just configuration of speed and retraction time.
