Tiny thermometer
Simple digital thermometer on Attiny 2313 microcontroller
Public Chat
Simple indoor digital thermometer on Attiny 2313 microcontroller using DHT22 sensor and display data on 8x2 LCD HD44780 display
NOTICE: Construction for home use only
Specifications:
- Power supply: 5V 100mA via Mini Usb;
- Temperature measure: 0 - 80 C real;
- Temperature measure: 0 - (-40) C int;
- Humidity measure: 0 - 100 % int;
Program Memory Usage : 1684 bytes 82,2 % Fulll
Data Memory Usage : 72 bytes 56,3 % Full
If you want to contribute to this project just let me know
Mcu works from 8MHz internal oscillator. But you should use external qrystal oscillator for more stability!
Source code written on C language in Atmel Studio 7 IDE.
For flashing MCU I used AVR ISP USBasp programmer and desktop app khazama
You should set Fuse bits only for change oscillators source (internal 8MHz or external 8MHz)! Leave the remaining bits at default!
If you use an internal generator, remove C3, C4 and Y1 from circuit
R2 resistor needed to adjust contrast of LCD
Device soldered on solder breadboard and put on KRADEX Z70 Housing case
Device circuit diagramm:
DigitalThermometer.zip
Firmware 1.0, Circuit (Dip Trace), Proteus 8 simulation files
x-zip-compressed - 1.28 MB - 04/14/2020 at 05:31
Download
  • 1 × ATtiny2313A-PU Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × WH0802A-YYH-CT 8х2 LCD Display Winstar
  • 1 × Housing case KRADEX Z70
  • 1 × Crystal oscillator 8MHz
  • 1 × DHT-22 Temperature-Humidity Sensor
View all 11 components
View all 2 project logs
