OpenThread temperature sensor project
Home mesh-network temperature/humidity sensor project.
The idea of the project is to build an end-to-end temperature/humidity sensor platform with a sensor board component (25.4mm/1inch diameter circular board) and a USB board border gateway router component to function as a host-board connected to a server (e.g. raspberry pi) connecting the board to MQTT or the internet.
  • 1 × SiliconLabs EFR32MG21 Cortex M33 multi-protocol radio chip
  • 1 × Texas Instruments HDC2080 Temperature and Humidity sensor
