I found why i went wrong in the beginning
A project log for Phabricator on raspberry pi
how to setup Phabricator on a raspberry pi 3B+ with a RAID on usb sticks to store the data somewhere else than on the SD card
nathannNathann 07/28/2020 at 11:170 Comments
I had some trooble with the RAID in the first place. its due to the USB drawing too much current so to fix this either use a powered USB hub or use only two USB stick with the max_usb_current=1 in /boot/config.txt then it run fine
