FigForth Built-In Words
A project log for MIKBUG on Multicomp
MIKBUG Running on Multicomp with 6800 CPU
land-boardscomland-boards.com 04/27/2022 at 18:290 Comments
Starting Forth book
TASK   FORTH   NOOP   VLIST   TRIAD   INDEX   LIST   ?   .   D.
D.R   .R   #S   #   SIGN   #>   <#
SPACES   WHILE   ELSE   IF   REPEAT   AGAIN   END   UNTIL
+LOOP   LOOP   DO   THEN   ENDIF   BEGIN
BACK   FORGET   '   R/W   HI   LO   BLOCK_READ   BLOCK_WRITE
?DISC   -->   LOAD   MESSAGE   .LINE (LINE)   BLOCK   BUFFER
DR1   DR0   EMPTY-BUFFERS   UPDATE   +BUF   PREV   USE   DABS
ABS   M/MOD
*/   */MOD   MOD   /   /MOD   *   S->D   COLD   ABORT   QUIT
(   DEFINITIONS   VOCABULARY   IMMEDIATE INTERPRET   DLITERAL
 LITERAL   [COMPILE]   CREATE   ID.   ERROR   (ABORT)   -FIND
NUMBER   (NUMBER)
LABD______________   PAD   HOLD   BLANKS   ERASE   FILL
QUERY   EXPECT   ?STACK   ."   (.")   -TRAILING
TYPE   COUNT   DOES>   <BUILDS   ;CODE   (:CODE)   DECIMAL
HEX   SMUDGE   ]   [   COMPILE   ?LOADING
?CSP   ?PAIRS   ?EXEC   ?COMP   ?ERROR   !CSP   PFA   NFA
CFA   LFA   LATEST   TRAVERSE   -DUP   MAX
MIN   SPACE   ROT   >   <   =   -   C,   ,   ALLOT   HERE   2+   1+
COLUMNS   HLD   R#   CSP   FLD
DPL   BASE   STATE   CURRENT   CONTEXT   OFFSET   SCR
OUT   IN   BLK   VOC-LINK   DP   FENCE   WARNING
WIDTH   TIB   R0   S0   +ORIGIN   B/SCR   B/BUF   LIMIT   FIRST
BL   3   2   1   0   USER   VARIABLE
CONSTANT   ;   :   C!   !   C@   @   TOGGLE   +!   DUP   SWAP
DROP   OVER   DMINUS   MINUS   D+   +
0<   0=   R   R>   >R   LEAVE   ;S   RP!   SP!   SP@   XOR   OR
AND   U/   U*   CMOVE   CR   ?TERMINAL
KEY   EMIT   ENCLOSE   (FIND)   DIGIT   I   (DO)   (+LOOP)
(LOOP)   0BRANCH   BRANCH   EXECUTE   LIT    OK
