Extended SRAM Test
A project log for MIKBUG on Multicomp
MIKBUG Running on Multicomp with 6800 CPU
land-boardscomland-boards.com 04/29/2022 at 14:040 Comments
The RETRO-EP4CE15 card has 1MB of SRAM on the card. The SRAM is in (2) 8KB windows with 64 banks in each window.
I wrote a test routine that writes ramp values to the SRAM and verifies it works.
The test program prints:
S0++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
 1+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++D
Where:
Hit a key at end to avoid resetting the Serial port until done.
Jumps back to SmithBUG when done.
Takes ~2 secs to run with 25MHz ROM/Internal SRAM and 16.7 MHz for External SRAM.
Assembled using A68 assembler
"..\..\A68 6800 Assembler\a68.exe" XRAMTEST.ASM -l XRAMTEST.LST -s XRAMTEST.SRE
Memory Map
