THE SIMPLEST WAY TO DRIVE BRUSHLESS MOTOR WITH ARDUINO USING SOLO (OPEN-LOOP)
A project log for SOLO, A Motor Controller for All Motors
SOLO is a Motor Controller designed to easily run most types of electrical motors, DC, BLDC, PMSM and ACIM. it's easy to use and versatile.
miladmilad 04/17/2020 at 09:210 Comments
Despite all the technologies available out there, brush-less motors are still challenging to be properly driven and control due to their complex and mostly expensive controlling demands they require! But this article is aiming to instruct you through an easy and affordable path for driving your Brushless motor using ARDUINO and SOLO.
Pleases read the complete article down below:
https://solomotorcontrollers.com/drive-brushless-motor-arduino-open-loop/
