More progress
A project log for Reverse Engineering Grant ASHP Remote Protocol
Reverse engineering the protocol used by our Grant ASHP remote.
mjc506mjc506 03/29/2020 at 21:220 Comments
So, more captures, and some decoding later...
When the system is sat idle, there is a periodic 'conversation' that takes place between the ASHP and the remote, starting each ~5 secs by the ASHP sending a packet, which is acknowledged by the remote, followed by some data from the remote, acknowledged by the ASHP:
-> 07 00 01 08 00 00 EF
<- 05 01 00 09 F0
<- 0E 01 00 97 08 0E 10 05 01 00 32 7B FE 82
-> 05 00 04 08 EE
<- 05 01 00 09 F0
<- 12 01 00 A1 00 16 00 00 00 00 00 00 00 00 00 33 26 DC
-> 05 00 04 08 EE
<- 05 01 00 09 F0
<- 0B 01 00 A3 A4 00 00 00 A4 47 C1
-> 05 00 04 08 EE
<- 05 01 00 09 F0
-> 05 00 04 08 EE
Also, on the stroke (or shortly after, if there is an ongoing transmission) of each minute, the remote sends:
0E 01 00 97 20 09 00 06 01 00 32 D1 62 C4
Other messages are also sent, but only on status changes - only the above are sent periodically.
There are several 'types' of packet.
The first byte is always the packet length (total, in bytes)
The second byte is either the sending station ID, or receiving, with the third byte (usually) the other. Packets from the remote are always 01 00, and from the heatpump 00 01 (apart from the 05 00 04 08 EE acknowledgement packet).
The 4th byte is perhaps the packet 'type'.
The last byte is a sum compliment checksum.
I have observed the following 'type' bytes:
0x08
This is seen as part of either 07 00 01 08 00 00 EF packet (requesting data from the remote?) or 05 00 04 08 EE (acknowledgement?) from the ASHP. Nothing interesting.
0x09
Only ever appears as a response (05 01 00 09 F0) from the remote to 07 00 01 08 00 00 EF from the ASHP. Again, nothing interesting here.
0x97
This one contains some data.
The remote sends day/time and stand-by/on data to the ASHP, and the ASHP sends the demand data.
0x98
This is sent by the ASHP back to the remote as an acknowledgement, and contains the same data.
0x99
Request from the remote for specific data from the ASHP.
Once this is sent, the ASHP will respond with 0x9A and 0x9C packets until the remote sends another request (I still need to find what it sends to stop requesting at all...)
0x9A
Data from the ASHP, usually in response to 0x99 packets, but also sent semi-periodically during DHW and CH demands.
0x9C
Data from the ASHP, appears to be sent occasionally and also in response to requests - perhaps just sends when a parameter updates.
0xA1
Sent by the remote periodically in response to the ASHP's 07 00 01 08 00 00 EF. Unknown, but must contain some data as some bytes change. (6th, 8th, 9th at least)
0xA3
Also sent by the remote periodically as above. Also unknown, but the 5th byte appears to increment, although I've not yet determined the trigger.
So, plenty of gaps still, but I should now have enough to listen in to most of the data I want, and send requests for the rest! The logic levels inside the remote are 5V, so I need to find (or likely quicker, wait for a new one in the post...) a logic level converter to interface with an ESP for monitoring over wifi.
