On a Pi 3 with the 2016 script, the failure is even more burning
Why can't the RPi guys keep a consistent system or at least preserve backwards compatibility ?
A new script is required, considering the list I recently found:
#define PI_01_REG_BASE 0x20000000 // Pi Zero or 1
#define PI_23_REG_BASE 0x3F000000 // Pi 2 or 3
#define PI_4_REG_BASE 0xFE000000 // Pi 4
And don't forget that this is the base of the peripherals block, not the start address of the GPIO block. In these cases, it's:
#define PI_01_REG_BASE 0x20200000 // Pi Zero or 1 #define PI_23_REG_BASE 0x3F200000 // Pi 2 or 3 #define PI_4_REG_BASE 0xFE200000 // Pi 4
thus:
$ grep gpio /proc/iomem | grep -i -E '20200000|3F200000|FE200000' 00000000-00000000 : 3f200000.gpio gpio@7e200000
It's getting tiring to have to rewrite stuff all the time...
The latest script is :
#!/bin/bash
# version 20210107
export GPIO_BASE=""
GPIO_LINE=$(grep gpio /proc/iomem) && {
echo "$GPIO_LINE" | grep -i 20200000 && export GPIO_BASE=0x20200000 # Pi Z or 1
echo "$GPIO_LINE" | grep -i 3F200000 && export GPIO_BASE=0x3F200000 # Pi 2, 3
echo "$GPIO_LINE" | grep -i FE200000 && export GPIO_BASE=0xFE200000 # Pi4
echo GPIO_BASE=$GPIO_BASE
Now how long is it going to work ?
