As outlined earlier there are still two fast switching transistor types on the market: The PMBT/MMBT2369 and the BVS52. Both are offered by Nexperia and On Semi.
The plot above shows a comparison of both devices. It appears that the PMBT2369 is quite a bit faster. The MMBT2369 shows a maximum at around 5V supply. At higher voltage (current), the saturation charge seems to dominate switching behavior. This trend can only be seen at >8V for the PMBT2369.
Minimum tpd of the MMBT2369 based RTL inverter is 6.8 ns, that of the PMBT2369 based inverter is 4.8 ns.
It's quite difficult to asses the actual origin of the speed difference, just speculating: The higher current gain will increase the miller capacitance of the MMBT2369. However this is mostly relevant while the device is turned on. The critical condition is the storage time of the saturation charge, which flows out of the base when VBE is already zero and the miller capactance plays no role.
The PMBT2369 definitly appears to be the faster of the two. In fact, the PMBT2369 seems to be the fastest bipolar switching transistor that is still available in high volume today.
Why even look at other devices? Unfortunately it seems that the PMBT2369 is only available in the relatively large SOT23 package. To build dense discrete logic (yes, it makes no sense, I know), it would be of interest to use much smaller packages such as SOT523 or SOT723.
Interesting, what kind of models did you use? And simulator?
What about PMST2369 in sot-323?
Its the PMBT2369 in a smaller package. so it should be fine. havent tried it, though.
btw, by parsing my spice models library I found that the BFP/BFR183 should ring at around 200MHz
Not sure I understand correctly? But when you drive RF transistors into saturiation they usually get pretty slow.
Simulations show that the PMBT2369 oscillates at 16.5 MHz. When I changed it to BFR183 it oscillates 208MHz@5V. perhaps he's "not enough RF" to slow down ;)
BFR182 oscillates at 68 MHz in the simulation.
BFP193: 98MHz
maybe the models is wrong, we just have to check...
Better to check in a real circuit. The question is also if the transistor is driven in "logic mode". Its possible to get to some operating setting where the ring oscillator basically operates in small signal mode. It will oscillator pretty fast, but it's not really indicative of switching speeds.
e.g. see here:
https://hackaday.io/project/176107-led-coupled-logic-lcl
this is clear. don't let him get saturated. Basics of ECL/CML.
The point of the PMBT2369 is that you can let them saturate and they are still pretty fast. It's a special type of transistor (gold diffused/implanted) and apparently the last of its kind :)
But all that said - it's quite possible that modern high end RF transistors are also pretty fast in switching. At least they like to oscillate a lot :). I haven't tried some of the newer SiGe ones in ring oscillators, only the trusty MMBTH10.
all girls know that gold diffuses better on diamonds ;)
May we trust simulations? I see a clear correspondence between simulation and reality in the example of MMBT2369 and BC847C. And I really want to hope that the other curves are close to reality too...
https://ibb.co/9qzmqgX
unfortunately twin brother PNP MMBT3640 is EOL since 2019
btw, are you sure about the quality of yours MMBTH10?
I used original onsemi MMBTH10 (The first M is for Motorola, which onsemi spun off from)
btw, have you shared your simulation somewhere?
You may see results here: https://ibb.co/6Bzynmg
Few more bjt's was added.
BC847 and MMBT2369 seem to match well your experimental data. but not MMBTH10
I have to reproduce your test setup ;)
You made me curious, so I tried a more modern RF transitor:
https://hackaday.io/project/170697-evaluating-transistors-for-bipolar-logic-rtl/log/224820-ring-oscillator-with-rf-transistor-bfu520
I believe the switching operation is simply not characterized and therefore not properly modeled in the spice models. RF guys usually want small signal S parameter models, they don't care about switching.
