Mechanical Drawings
A project log for LR1110 module - Tiny LoRa & WiFi/GNSS positioning
Leveraging the LR1110 to create the smallest geolocation+LoRaWAN combined module for use in tracking.
sensorsSensors 07/02/2020 at 13:010 Comments
I've just finished the mechanical drawings and pad layout for the datasheet
(All units are in mm)
You'll notice the height is 2.8mm rather than the planned 2.5mm. That's just because of the 1mm PCB for the first revision to make manufacture easier, but I'll likely move to 0.5mm thickness PCB if I can for a total height of 2.3mm!
