Turn a mini fridge into a freezer
A project log for WiFi Waterbed and Freezer Temperature Control
The old mechanical thermostat failed ON so I replaced it with a WiFi NodeMCU system with web page HMI for control/monitoring.
nodemcu12ecanadanodemcu12ecanada 04/29/2022 at 17:170 Comments
Our chest freezer suddenly died as well. With the same components I turned a mini fridge into a freezer until we get a new one. The thermostat wouldn't go low enough. So I replaced it with a digital temperature sensor and microcontroller. Clock is used to delay restart for 200 seconds after power failure or compressor OFF. Refrigeration compressors need to be off for some time before restarting so they don't try to start under running pressure. Added a 12V pc fan inside and a USB fan blowing on the compressor.
