Hoverboard motor power output
A project log for Hoverboard wind turbine
Wind turbine using mostly cheap broken hoverboard parts
marin-bMarin B. 05/11/2020 at 10:530 Comments
This guy OpenSourceLowTech helped me out to get some specs for a standard 6.5 inch hoverboard motor. Visit his you tube. He is doing some great stuff.
So what can i expect out of a hoverboard motor?
Looking at about 50-60VAC (three phase) at 1000 rpm and
at least 300W, depending on load.
So this could be good for a horizontal axis wind turbine.
These motors are cheap and sometimes free from broken hoverboards since the most common thing to fry on a hoverboard is the sensor board. The motors are usually fine.
The hoverboards also have a a good alu case with plastic all around it. Looks kind like a wind turbine housing when you split it in the middle and that is what im planing to do.
