Completing the Project
A project log for Open Source Social Distancing Meter
An open source solution to social distancing that uses inexpensive parts and uncomplicated code.
jordanbrandesjordanbrandes 05/11/2020 at 17:590 Comments
The hardest part of building this was the case. I originally intended it to go into an Altoids tin but that became way too complex. I eventually found an old lanyard from a convention I attended and cut out holes in the plastic for the Uno GPIO holes. That worked very well.
